MSI N260GTX Lightning Review
Written by Mark Mackay
July 6, 2009 | 10:15
Tags: #55nm #geforce #gtx-260 #lightning #maxcore #n260gtx #overclockable #review
Companies: #msi #nvidia
Fallout 3
Publisher: Bethesda
Fallout 3 is the revival of Interplay’s excellent Fallout series of games following many years out of the limelight. It’s developed and published by Bethesda and, judging by the success of the game, we’ll be seeing more Fallout games in the future.
Despite using the Oblivion engine which is now a few years old, the game looks absolutely stunning. Bethesda has spiced up the graphics a bit since Oblivion and has extended the engine – there are some great explosions, soft shadows and smoke effects that are particularly noteworthy.
We tested the game by manually playing a section of the game that incorporates a number of explosions and effects that you’re likely to experience during your time in post-apocalyptic Washington DC. We recorded the frame rate using FRAPS.
The in-game details were set to their highest values and both anti-aliasing and anisotropic filtering were controlled by the application settings instead of through the driver control panel. This meant that transparency anti-aliasing was enabled, along with HDR and all of the cool smoke effects.
Fallout 3’s engine is by default capped to 60 frames per second, which can make benchmark results very unclear, especially when testing at lower resolutions or with high end graphics cards. To remove the 60FPS cap you’ll need to find the Fallout3.ini file in \Documents\My Games\Fallout3 and edit the file so that iPresentInterval=0. This removes the frame rate cap, and allows us to get a much better idea of a card’s abilities.
MSI N260GTX Lightning Review Fallout 3 MSI N260GTX Lightning Review Fallout 3
Fallout 3
1,680 x 1,050 4xAA 16xAF, Maximum Detail
  • ATI Radeon HD 4870 X2 2GB
  • Sapphire Radeon HD 4890 1GB Atomic
  • Asus Radeon HD 4890 1GB
  • ATI Radeon HD 4890 1GB
  • Nvidia GeForce GTX 285 1GB
  • Nvidia GeForce GTX 275 896MB
  • MSI N260GTX Lightning
  • Nvidia GeForce GTX 260-216 896MB
    • 83.7
    • 56.0
    • 82.4
    • 44.0
    • 79.2
    • 38.0
    • 79.2
    • 38.0
    • 78.2
    • 45.0
    • 73.6
    • 40.0
    • 70.4
    • 36.0
    • 65.1
    • 34.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
Fallout 3
1,680 x 1,050 8xAA 16xAF, Maximum Detail
    • 83.0
    • 47.0
    • 80.4
    • 33.0
    • 76.3
    • 32.0
    • 76.3
    • 32.0
    • 69.8
    • 33.0
    • 64.1
    • 30.0
    • 58.4
    • 26.0
    • 56.6
    • 26.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
Fallout 3
1,920 x 1,200 4xAA 16xAF, Maximum Detail
    • 83.6
    • 47.0
    • 79.5
    • 38.0
    • 74.9
    • 31.0
    • 74.9
    • 31.0
    • 74.7
    • 39.0
    • 67.1
    • 32.0
    • 65.9
    • 29.0
    • 62.9
    • 29.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
Fallout 3
1,920 x 1,200 8xAA 16xAF, Maximum Detail
    • 82.8
    • 45.0
    • 77.4
    • 29.0
    • 70.9
    • 29.0
    • 70.9
    • 29.0
    • 62.1
    • 29.0
    • 58.1
    • 25.0
    • 55.8
    • 22.0
    • 51.9
    • 21.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
Fallout 3
2,560 x 1,600 0xAA 16xAF, Maximum Detail
    • 83.6
    • 48.0
    • 75.6
    • 40.0
    • 74.9
    • 35.0
    • 71.3
    • 33.0
    • 69.2
    • 34.0
    • 69.2
    • 34.0
    • 66.2
    • 31.0
    • 63.0
    • 29.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
Fallout 3
2,560 x 1,600 4xAA 16xAF, Maximum Detail
    • 81.1
    • 30.0
    • 63.6
    • 25.0
    • 61.6
    • 27.0
    • 58.5
    • 21.0
    • 58.5
    • 21.0
    • 56.0
    • 23.0
    • 52.8
    • 19.0
    • 48.9
    • 17.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
Fallout 3 was a consistently bad result for the Lightning. It was unable to play the game smoothly at 2,560 x 1,600 with 4x AA or higher. If you want to play Fallout 3 at these settings with all the sauce turned on then you would have to invest a little more cash in a Radeon HD 4980 1GB which is about £20 more.
